Thread: Calcium?
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Calcium?
    Is the white discoloration on tile grout calcium build up? I've gotten my CH down to 320 (from 450). Our tap water isn't much better (lots of white build-up around faucets indoors). What's the best (safest) way to clean it? I tried scrubbing, but doesn't do much.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    38,305
    Re: Calcium?
    Probably ... a high pH can make it show up more rapidly.
    A mixture of muriatic acid and water sprayed on and then scrubbed can help get rid of it.
