Results 1 to 9 of 9
Thread: Pool surface problems
    May 2012
    South Florida
    36
    I had my pool drained by the contractor after a new pebble finish was applied (marbletite) because of improper application the first time. The cream was never cleaned off properly the first time and surface was very blotchy. The contractor acid washed the surface again today. The surface is now 3 mo old. There is a little streaking in the finish and I would like to blend it in a little better.
    Should I do a fresh acid start?
    IG ~14,000 Gal
    Pentair clean n clear Cartridge 100g/
    SWG Aquapure 1400
    Hayward XL Cleaner
    Premix Marbletite Freestone series
    1.5Hp 2 speed
    TF-100
    May 2012
    South Florida
    36
    Re: Pool surface problems
    Somebody out there must be able to give good advice. I can't trust the contractor anymore and I don't give a **** about the warranty. I just want the pool to look good.
    Thanks
    IG ~14,000 Gal
    SWG Aquapure 1400
    Hayward XL Cleaner
    1.5Hp 2 speed
    TF-100
    Smykowski's Avatar
    Sep 2011
    3,065
    Try posting under Equipment - Startup and Construction. Since you're kinda "starting over", you might find more expertise there. This forum is more for spring startup, chemicals, etc.
    May 2012
    South Florida
    36
    Thanks!
    IG ~14,000 Gal
    SWG Aquapure 1400
    Hayward XL Cleaner
    1.5Hp 2 speed
    TF-100
    30,419
    I moved the whole thread to "under construction" I think your lack of responses is that there are VERY few, if any pool plasterers on this website and even if there were, I think you question may be a little too subjective with no black/white answer.
    Qwaxalot's Avatar
    Jun 2012
    439
    Some variation in a pebble finish is normal.
    That said, can you tell if the streaking is still some cream? If it is, and you have a bypass on your heater, you can try the acid approach, accompanied by vigorous brushing.
    Caution: if the problem is being caused by unevenly mixed aggregate, you might make it worse.
    This is a highly subjective issue, and sometimes expectations exceed reality, especially in dark aggregates.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    May 2012
    South Florida
    36
    The aggregate was evenly mixed. The problem was uneven acid washing and surface was not power sprayed per manufacturer specs. The result of the draining and subsequent acid wash was an overall improvement, but acid was not flushed well afterwords and there are drip lines in shallow end where acid remained prior to fill. I did acid start again and there is improvement. I figure I will continue to brush for a day or two and then raise pH if that sounds like a sound idea.
    IG ~14,000 Gal
    SWG Aquapure 1400
    Hayward XL Cleaner
    1.5Hp 2 speed
    TF-100
    Jul 2011
    Arizona & California
    803
    If your contractor doesn't have good experience with performing acid washes, then perhaps another contractor might be able to improve the appearance.
    Posting a picture of the plaster streaks (when shaded from sun) would help with advice and disagnosing problem.
    May 2012
    South Florida
    36
    I won't contact another contractor. Down hear in Florida you are really taking your life in your own hands. It's up to me now. I will take another look tomorrow after 4 more brushings and see. Thanks for the advice.
    IG ~14,000 Gal
    SWG Aquapure 1400
    Hayward XL Cleaner
    1.5Hp 2 speed
    TF-100
