Thread: Timer won't shut off
    Jun 2012
    St Pete FL
    45
    So the pool has a timer that is set to run from 8-4. If I want to turn the pump off during that time to attach the hose and clean, it will not shut off. I have to actually turn it off by going to the electrical box and flip the breaker off????
    Why is it doing that?
    5,000 gal Fiberglass paper cartridge filter, autochlorinator, BBB
    20,000 gal Pebble Tec paper cartridge filter, BBB
    15,000 gal Pebble Tec, DE filter, autochlorinator, BBB
    20,000 gal Pebble Tec, sand filter, BBB
    38,475
    Re: Timer won't shut off
    Welcome to TFP!!!
    Obviously sounds like it may be broken.
    What timer do you have ... post up a picture.
    The mechanical intermatic timers have a small zone near the ON switch that will not allow you to turn the power off ... but that may not be the problem here.
    Jun 2012
    Farmington wv
    92
    The timer motor is most likely burnt up. Sometimes they will turn on but when it gets to the off pin the motor just stops. We rebuild them at work but if it is just a 120v timer it will be cheaper to just buy a new one.
    13500 gal 24 foot round x 4 foot deep above ground pool. Sand filter with 1.5 hp pump. City water
    Jun 2012
    St Pete FL
    45
    Thanks I had a friend look at it yesterday with me and of course it worked fine. Will try to get a pic up here.
