Results 1 to 8 of 8
Thread: Is it ok to add more than drop at a time to the FAS-DPD test
    Derry, ME
    19
    Since I have a high CYA value (currently 70 but trying to get it down) I have to maintain around 10ppm of FC.
    This equals 20 drops of the FAS-DPD reagent. I don't have the fancy swirling machine so instead of swirling between each drop, I put 5 in, swirl, 5 more, swirl, than start swirling every 2 drops unil I see it start to see the test sample start to clear up. Is this affecting the accuracy of the test by doing it this way (instead of swirling after every drop)?
    15x30 Esther Williams semi-inground
    Hayward DE filter with 1/2 HP super pump
    4 2x20 Sungrabber solar panels
    TF100
    Mar 2011
    Sunny Central Florida
    91
    Re: Is it ok to add more than drop at a time to the FAS-DPD
    I do the same thing For TA & Ch too....
    I actually have perfected a swirl with my right hand while working the dropper with my left. I'm pretty proud of myself, LOL.
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    Derry, ME
    19
    I've tried that and I end up messing up the test!
    TF100
    Sep 2009
    Greentown, IN
    914
    I tend to do several drops at a time... just keep a close eye on it getting ready to turn so you don't overshoot your mark.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Derry, ME
    19
    Thanks a lot. I do keep an eye on it during the process.
    TF100
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I know I tend to do drops in sets of three until I get close to what I am expecting... then I drop to single drops.
    -- Guy --
    Mar 2007
    San Rafael, CA USA
    12,082
    Just make sure that the drops are well-formed when you add them. If you squeeze too hard and have the drops come out too quickly, then they will be smaller drops and that will affect the result making it artificially too high. Also be careful about static electricity which can make the drops "squirt" out. Y'all know what a good-looking drop looks like when you see one...
    Jun 2012
    Louisville, KY
    266
    Agree on well formed drops. I know where my fc is around so I add 6 full drops and then go from there for my target of 5. Just make sure you swirl really well for a few seconds after the big dose of titrant.
    You're doing a titration. Keeping the solution thoroughly mixed is the key. Takes me maybe 5 seconds to get it all mixed up on this test. It's the easiest one.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
