Thread: When to Start My SWG
    Jun 2012
    Marysville, Ca
    2
    Been learning lots here. I got the test kit, I shocked my pool, as of this AM:
    FC 7.5
    CC 0.5
    PH 7.5
    TA 120
    CH 230
    CYA 40
    Pool looks better this am than it has in a week. CYA is slowly coming up. Needs vaccumed, bought new vac at wal-mart, but of course, my pole doesn't work with vac head. When junk on bottom of the pool gets mixed up will that change my numbers? When can I turn the SWG on? Going to use pool calculator and bring TA down some.
    3284 gal, ag, intex cartridge filter pump, swg, easy set pool
    22,553
    Re: When to Start My SWG
    Welcome to TFP.
    Did you pass the OCLT?
    Is the water clear?
    If the answer to both is yes, then you can go ahead and turn the SWG on.
    When the stuff gets stirred up it may use up a little FC, but it won't be much.
    Butterfly's Avatar
    South Carolina
    10,045
    What is the salt level or how much salt did you add?
    You're done SLAMing when:
    Jun 2012
    Marysville, Ca
    2
    I did pass the OCLT this morning, but the pool needs vacuumed. Doing that tonight. My salt level was 264? a couple of days ago, this morning the pool calculator recommends adding 10lbs of salt. I have pool party tonight sooooo, I'll be interested to see my numbers after. Thanks for all the help as I continue to read, then read again, my understanding of this process is becoming as clear as my pool.
