Thread: Testing SWG any difference then a non-SWG
    Aug 2007
    Austin, TX
    341
    My neighbor has a SWG pool and loves how my pool looks. She laughed at me when my wife has complained about all the test kits that I have bought over the last year. Recently, she asked if I could test her water for her weekly which I don't mind for it lets me use my test equipment even more. I never had exposure to testing SWG pools, are there any differences in testing? I understand I will need the TF100 test strips for the salt, is there any thing else needed or that I need to know? I will not make any chemical adjustment that is up to her! I put her in touch with Jason's calc as well as to this website. My job is getting her the numbers and the rest is up to her.
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    The only thing is that the minimum FC/CYA relationship is not the same for a SWCG pool. Find out what level the SWCG manufacturer recommends for the CYA and salt, and you should be set.
