Thread: Replacing lights
    Mar 2012
    Kansas City, MO
    59
    Replacing lights
    Do you need to replace the lens o-ring when you replace the bulb?
    Edit: It's a 500w 120v pool lamp. Is there an LED replacement I can use instead?
    15k gallon IG kidney pool with attached spa
    plaster
    sand filter
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Replacing lights
    you don't need to, but it wouldn't hurt to replace it. You need the model number of the light to check if there is an LED replacement
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
