Thread: Best check valve for Liquidator
    Jun 2010
    San Antonio
    424
    So, I have a used Liquidator and I need to replace the check valves. I have seen the original grey ones, the little white John Guest ones, some black ones that Rabbit used, and there may be others. Has any one of these turned out to be more reliable? Is there another better choice?
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    22,551
    Re: Best check valve for Liquidator
    I've used these SMC check valves with good luck. They have a low cracking pressure and large body.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Jun 2010
    San Antonio
    424
    Dave, Would this be the one:
    1/4" FNPT Polypropylene Check Valve w/FKM Seals & 302 SS Spring
    Maximum Operating Pressure 125 psi. Maximum Operating Temperature 140F. Seat Area Open Diameter .438. The 694 Series Check Valve covers a wide range of air and fluid applications. The 694 Check is a compact design with a 1/3 psi cracking pressure, high flow rate, and a positive seal at very low back pressure or slight vacuum.
    US Plastics Item 22231 Looks like it is Black. It is the one suggested by Rabbit
    Larry in Texas
    22,551
    That's good enough. I used the 3/8" because I had the adapters and I figured the larger disc surface the better.
    Jun 2010
    San Antonio
    424
    I was going to ask about the 3/8." I think I will go with 3/8" as much as possible. Since the Flow gauge requires 1/4" I will have to use 3/8" barbed because I can't find a 3/8" speed fit x 1/4" NPT. I only found a 3/8" SMC needle valve with barbs at US Plastics, so I will use that as well. I know the barbed fittings decrease the flow, but I have not found a way to avoid them on these two parts.
    Larry in Texas
