Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Solar Covers - what do you think
    Aug 2011
    Augusta, Kansas
    88
    We have a 16x32 Ultra Frame Pool (salt water)....it's the coldest darn thing ever! The only times we don't hear complaints was during our last 10 days of 100 degree temps. Mind you the 10 year olds don't care but the high schoolers (and older ) tend to float and get out.
    There is refreshing but WOW! I like my pool a bit warmer. Monday I bought a thermoter and at 6 pm it was 84 degrees. We've been in the upper 90s/low 100s and it had been in full sun from 9 am - 7 pm and we'd not put any fill water in that week (we lose about two inches a week due to high wind and evaporation). At 7 a tree starts to shade 1/3 of it until sun down - note the sparklie water reflecting on the side of the pool - thank you troublefree pool!!!
    [attachment=0:3g1try21]pool.gif[/attachment:3g1try21]
    We are toying with the idea of investing in a solar blanket next year (and thus building some sort of reel so that the boys can remove it themselves) and I've a few questions.
    We have the over the side skimmer that floats in the pool. Also, I run the filter and SWG overnight.
    • Do they really help?
    • How does the solar cover stay on the pool with the pump running? Is the pump supposed to be off?
    • If the pump is on do you have to do something so that the skimmer doesn't get covered?
    • How do they behave in HIGH wind locations - because our pool is in ULTRA high wind area (we have cord in two corners of the pool to tie up the floats so they don't go sailing off into the next county.
    Any other information on your solar cover expierence would be great! Thanks everyone!
    Diane
    15,000 salty gallons - 24' x 12' x 52" Intex Ultra Frame Pool
    Intex Sand Filter, Pump, SWG - TF-100 and speed stir
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Solar Covers - what do you think
    Man, I have to fight to get to 84, 84 is like a bath way up here.
    The solar blanket will definitely help with heat loss at night, the pump can run while it's on, the blanket won't hurt anything. I'd recommend getting a good one that's a bit thicker so it does a better job. You may want to consider adding a solar heater as well.
    Jun 2012
    MA
    347
    I was going to say the same thing. I am happy when my pool gets up to 78 degrees and I use a solar cover. 84 would be like bath water.
    I wouldn't ever go without a solar cover. On a sunny day I can expect a few degree gain and overnight I would say it cuts down the loss by at least 60-70%. I haven't used it in a couple weeks, but it looks like within the next two weeks it will get some use. I also use about 1/3 as much chlorine when it's covered.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    I live in Oklahoma and have an Intex 18'x54". I have a clear diamond solar cover that i keep on all the time except of course when we swim (at least I did). Last Friday it was 103 degrees with very little wind and alot of humidity. Me and my daughter went to go swim at 9:00 that night and holy **** the water temp was excacly 100 degrees. We stayed in for about 15 minutes and I told my daughter I couldn't take it any more. I was sweating like I was in a hot tub with no bubbles. So now if the temp is above 100 i leave the cover off (just have to deal with the water evaporating) but the water stays around 90-95 which is great. Of course the 15 minutes of 100 degree water with no bubbles got me thinking about how to add some jets to make a big hot tub.Lol.
    16 mil clear and you won't look back, you can build a reel for it or just cut it into three or four pieces so it's easier to handle.
    Intex 16x48 Ultra Frame
    5100 gallons
    Intex Sand Filter and Pump
    BBB Bliss Baby!
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    It's a must have where I live in my opinion. I like the clear ones and use a reel that goes across the skinny side of my oval pool. My teens can easily roll and unroll it. Temps drop into the 60's at night at this time of year but with the cover and 2 solar panels I maintain 82 or so degrees unless really warm out. Like mentioned, the cover really helps with maintaining FC and water level. If my pool temp gets into the 90's I will roll the cover up at night so it cools off but it will stay on during the day. As for wind, not a problem because there's some suction affect plus the water level is below the pool frame. The cover sits on the water. I do lift the cover edge up near the strainer and put it on the frame held with a water jug. As for the cover itself, I buy them on e-bay. I have a 12mil one on the way right now. My old one is getting bubble detachment. I've read that 16mil is a bit heavy to deal with and not worth the extra thickness but that may be someone's opinion. 3 or 4 years seems to be the max on these covers.
    Here's what I bought although the reel I got locally on sale for $100 I think.
    http://www.ebay.com/itm/18-x-33-Oval-12 ... 6rk%3D1%26
    http://www.ebay.com/itm/Above-Ground-Sw ... 2eb0e655f9
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    Any kind of cover that would prevent blowing wind coming in contact with the water surface will work.
    Your pool loses too much heat because of high evaporation caused by wind blowing over the surface, this is called evaporative cooling and it can work either for or against us, depending on the situation.
    Donīt be fooled by the sheep on my bike, I swim with fish in my sound equipped pool.
    Apr 2010
    Buckeye, AZ 85326
    619
    With that much sun and a cover you will be in the upper 80's in a few days I would imagine.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I bought one for my new pool while it was being built. It's still in the box. The pool took 40 hours to fill and has been 90 degrees since we started. I am freezing empty bleach bottles filled with water to cool it off. I probably won't need the solar cover. lol
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Quote Originally Posted by Glock
    Well, you are a bit more South. My new cover came in today, talk about fast seeing the shipping is included. Love Fedex.
    Mike
    Jul 2009
    Olney, MD
    218
    Quote Originally Posted by asxetos
    Yes, I definitely agree.
    From personal experience, I can safely say to cheap out on this one... don't blow a ton of cash on a thicker blanket. My 16 mil disintegrated after 2 years and the so called warranty is really just a fancy way to get you to buy a new cover from the same seller (because they don't replace, they prorate). So, I am in season 3 with my el cheapo blue cover that is super thin and light and easy to roll up. I didn't even cover it this past winter (big oops) and I had covered the expensive every winter!
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    redhdgirl417's Avatar
    Sep 2012
    Mid-Michigan
    127
    I too leave my solar cover on the pool at all times unless swimming (have the Solar Saddle installed on one side of pool for storing it when not on) and it definitely helps keep the water warmer at night and nice and toasty in the afternoons here in Michigan. Thinking of adding a couple of solar panels in the future.
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
    Sep 2011
    Atlanta Ga
    310
    I'm going to get a solar cover. I just read over this discussion and would appreciate any links to other discussions of solar covers on the pool forum.
    From what I have read here, I think I will get one of the cheap ones from Amazon. Here is a 20'x40' 12 mil for $132.
    http://www.amazon.com/Mil-Pool-Solar-Co ... pool+cover
    My pool is 36'x18' oval. Should I get a cover that is a little larger, or one that is exactly 36'x18' ? Amazon has both sizes.
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    I find the exact size easy to deal with. It fits nicely inside the pool. With the size you mention it would hang over the edges. Maybe that's not a big deal on an IG but would be a pain on an AG. These things are a bit cumbersome to deal with so bigger to me would be worse. A reel is a good add-on for it.
    Mike
    Sep 2011
    Atlanta Ga
    310
    Thanks for your thoughts Mike. From the picture I see a tree near your pool. How well does the solar cover work with keeping leaves out of the pool?
    27000 gallons
    Pool built in 1971.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    I have trees almost all the way around my pool. It keeps some out but I get a bunch of wind where my pool is so some of the leaves blow to one end and fall in. I guess that would be a plus to a bigger cover, you should get no leaves because you can scoop them off.
    Mike
    Jul 2012
    Chicago, IL
    358
    Tom, I recently had my cover on for about two weeks and I have a lot of trees around the pool. The cover definitely keeps a significant amount of leaves out, but with the wind some of them will still slip in around the edges. I was moderately surprised at how many had gotten in when I removed it, but there is no question it makes a material difference.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Jun 2017
    Hesperia California
    12
    I just put up my pool. Better late then never. I have a solar cover that is 18 ft on 17 ft round. My question is tri fold. Can i run my 1000c pump with the solar cover on. Can i pull back my cover and broadcast needed chemicals ie: stabilizer and bleach. Is it best to run pump at night ir during day while not swiming. Ps pool should be full soon.
    Above ground Summer Escapes metal frame.
    17'x52" 6280 gallons. Standa1000c pump.😊
  20. Back To Top    #20
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    894
    Yes no worries with the pump running. Pouring the bleach in front of a return and you should be right.
    We suggest adding stabiliser in an old sock hanging in front of a return.
    It doesn't really matter when you run your pump- but it is always good to have it running at least 1/2 an hour before you perform your testing and when you are adding chemicals to the pool.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
