Thread: Quick question about CYA in tri-chlor pucks
    Jul 2011
    Mesa Arizona
    190
    I'm getting a friends pool up and running for him until he is able to move from Oregon.
    I filled the pool, got the pumps and filter working and I added enough CYA to get it to about 25 PPM. I want to bump that up a little as the pool is in direct sunlight most of the day here in Arizona but I don't want to go too high. For the short term, I'm just using the pucks but I just put the CYA in there yesterday so it doesn't show up on the tests yet.
    I'd like to know how much a single 3" puck will raise the CYA level in a 14k gallon pool?
    Thanks.
    Mesa Arizona. Old school 26,000 gallon in ground plaster pool with sand filter built in 1984.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Quick question about CYA in tri-chlor pucks
    Most 3" pucks are about 8 ounces, so 1 would raise the FC 3.9 ppm, raise the cya 2.4 ppm, and lower ph ~0.21 (though ph change will depend on TA and starting ph). I got these numbers from the "effects of adding chemicals" section of the poolcalculator.com.
    Jun 2010
    Glendale, CA
    513
    Here's a good post with info. If you know the exact weight you can calculate the exact amount.
    A 7oz puck will add about 2ppm per puck
    how-much-cya-per-10k-gallons-per-tri-chlor-puck-t976.html
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by lightingguy
    In a 14K pool a 7 ounce puck will add 3.4 ppm FC, add 2.1 ppm cya, and lower ph ~0.18 (same caveats as before).
    Jul 2011
    Mesa Arizona
    190
    Thanks guys. That helps a lot.
