Thread: what to dose my FC at?
    Oct 2010
    michigan
    284
    CYA 40 min FC 3 target FC 5 shock 16
    so what should i dose my FC too at night? or early in the morning before the sun comes up?
    is it ok to go above the target FC of 5? with this hot weather 90-95 past 7 days, uses 3-5 FC per day
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,975
    Re: what to dose my FC at?
    If you're losing 5 and minimum is 3, take it up to 8.
    It's safe to swim in up to shock level.
    My CYA is 60 and I've been adding 5.5 per day, I don't let it get under 7, most often it's 7.5 at night. 7.5+5.5=13 - I add my chlorine between 7:30-9pm. Lately I've been waiting until around 8:30 when the sun is setting.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, what Richard and Speedo said ^^^^
    I prefer to dose after the sun is off the pool in the evening because the chlorine only has to work on anything organic.
    You're done SLAMing when:
