Thread: How to check a liquidator check valve
    Jun 2010
    San Antonio
    424
    Can I determine whether a Liquidator check valve is good before I install it?
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: How to check a liquidator check valve
    Quote Originally Posted by Txmat
    You should be able to blow through it one way but not the other. If you ever want to try it after you install it, rinse it off good under the faucet!
    Jun 2010
    San Antonio
    424
    Thanks.
    Larry in Texas
