Thread: K-1716 Taylor Iron Test, how many tests can it do?
    Oct 2010
    michigan
    284
    how many tests can it do? also about how many PPM will it stain the walls on fiberglass?
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Jun 2012
    NJ
    50
    Re: K-1716 Taylor Iron Test, how many tests can it do?
    From what I've read, it has .75 oz of reagent 1 (R-0851) and 1.5 oz of reagent 2 (R-0852) (about 22ml / 44ml respectively). You need .5ml of R-0851 and 1.0ml of R-0852 for each test, so you should get about 44 tests out of the kit. Don't know about the staining.. perhaps someone else can help on that!
    24,000 gallon in-ground plaster, Pentair FNSP60 60 sq. ft. DE filter @ 9,000 GPH, 2HP WhisperFlo pump, CircuPool RJ45 SWG, 399k BTU Raypak heater, built 2008. Taylor K2006C kit.
    Montreal Canada
    326
    The kit comes with 22 mL reagents, you're good for 22 tests.
    Quote Originally Posted by CaOCl2
    Yes, but there are two bottles of 22 ml each of R-0852, as can bee seen here. As rtkane said it is 0.5 ml of R-0851 and 1.0 ml of R-0852, as can be seen here, so 44 tests (+-1).
    Depending on other factors, like PH, fiberglass starts to stain somewhere around 0.1 to 0.2 ppm of iron. It will stain at lower iron levels when PH is high, and only at higher iron levels when PH is low.
    Montreal Canada
    326
    Oh that's right! Sorry! My error!
