Results 1 to 8 of 8
Thread: Concrete slope question
    Aug 2007
    Powhatan VA
    50
    The weather is finally cooperating and I am grading around the pool preparing for concrete. The contractor I have been talking to said I should only have 1/4 inch slope from the edge of the pool to the outside edge of the concrete, no matter the width. I am getting 8' on two sides and 5' on two sides. Is this slope correct ? It seems to be cutting things a little close. I'm not even sure I can get it that close.
    As always, thanks for the help.
    20x40 IG Vinyl
    33k Gallons
    Triton TR-100 Sand Filter
    Pentair WFDS-6
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Our installers said they went for 1/8" per foot of decking. I have seen some deck coatings that require/recommend more slope, but this has worked well for us.
    Gulfport Mississippi
    54
    First of all you are correct in your assumption that he could not maintain that tolerance and that will lead to ponding then staining IF you are saying that he recomends a total of 1/4" fall but i believe he is refering to 1/4" fall per foot and that would be just fine.
    What you do want to see at least 1/8” per foot, at 8 feet that will equal one inch and 1/4" would be two inches.
    That may seem like a lot but you will never notice when it is poured.
    This will facilitate drainage and help eliminate ponding in low spots.
    Think of it this way the IBC code contains requirements for drainage and grading in Section 1803.3 and 1805.3.4.
    These requirements minimize the possibility of foundation failure due to poor drainage.
    Section 1803.3 generally requires a 5% slope away from the building perimeter for a distance of 10 feet.
    This does not apply here but it does illustrate the importance of achieving proper slope and how much is required.
    10,000 Gal. - Plaster – I.G. - Sand Filter – NOT USING MY Auto Puck Chlorinator.
    30,403
    I'm with John and Bpotter....1/8 is invisible....1/4 is somewhat noticeable (but not much) over 10' or so.
    (per foot)
    Aug 2007
    Powhatan VA
    50
    Thanks everyone for the quick replies. I asked him specifically on the phone yesterday ' 1/4" per foot, or 1/4" total ? ' and he said 1/4 inch from pool to edge. I am going to shoot for 1.5 inches on the 8' sections and 1" on the 5' sections. I agree, I don't think it's going to be noticeable, even to the contractor.
    Thanks.
    20x40 IG Vinyl
    33k Gallons
    Pentair WFDS-6
    We have at least 1/4 inch per foot when I had the concrete done for our pool....and I insisted on it. Yes its noticeable...but here in Texas when it rains, it can dump an inch every 15 minutes. And everything will be satuated within 30 minutes and will start to travel up hill if it can. Don't want any landscape, manure water in my pool.
    Jan 2008
    Malaysia
    109
    The other thing you have to consider is the wind speed. If it's well covered at all sides, then it's OK. My roof slope of 30 degree have rain water travelling upward when the wind start to whip. I would prefer 1/4" per foot.
    8,000 gal IG concrete & tiled lap pool, 1/2 hp pump, 24" sand filter, SWG Auto Clean, whole pool under shed, 3 X 2ft waterfall one end overflow the other end. TF100 Testkit. 80 F Water whole year round.
    Jan 2008
    Forney, TX
    162
    That guy is on drugs if he's recommending that you have 1/4" total fall in 8'!! That's crazy! We do a lot of commercial work and as the others said, 1/8" per foot is the industry standard minimum slope for flatwork. 1/4" per foot will shed water quicker. Like Barco I'm in Texas and we also went with 1/4" per foot. I'm glad we did because in some of the hard rains we'd have stuff washing into the pool if it was any less. One of our neighbors had minimal slope in their decking and mud would wash into their pool during really hard rains. They HATED it!
    Our pool adventure... click here
