Thread: Aqualink RS6 All Button Panel With Pwr Ctr Rev R PCB RS8
    Aug 2008
    Dallas (Plano), TX
    41
    Does anyone know if a P&S RS6 All Button panel can continue to function fine if connected to a Rev R PCB with a P&S RS8 CPU?
    I know that I need an RS8 All Button panel, or a One Touch panel, to get access to the last two devices. But if I were to just upgrade my Rev K P&S RS6 PCB with a current release Rev R P&S RS8 PCB, and later go to the expense of changing my All Button panel from an RS6 to an RS8, will my RS6 All Button panel contiue to operate just fine?
    Would very much appreciate some assistance.
    Many thanks!
    Best regards,
    Bill
    30 KGal IG plaster pool with diving board & spa, built '96; 2 speed (2.2/0.28 THP) AO Smith B2983 hi efficiency motor for circ (3 skimmers w/ 1.5" lines & drain w/ 2" line) (replaced original 1 speed Sta-Rite Max-E-Glas II 2.0 THP pump in 2011); waterfall w/ Sta-Rite Max-Glass II 2.5 THP pump w/ 2.5" lines, Polaris 280 pressure-side cleaner w/ 3/4 HP pump, Sta-Rite System 3 Vertical Grid 53 sqft DE filter, AquaLink RS6 P&S w/ 52 pin Rev K.33 controller, Rainbow offline tri-chlor erosion feeder, 450 KBTU/hr Rheme gas-fired heater, Dallas climate, 10/kwh current electric rate, energy monitoring system at http://www.welserver.com/WEL0043
    Aug 2008
    Dallas (Plano), TX
    41
    Re: Aqualink RS6 All Button Panel With Pwr Ctr Rev R PCB RS8
    I got an answer from a pool professional that I thought I'd pass along:
    Yes, use of an RS6 all button panel with a system with an RS8 PPD/chip will work fine, you just won't have control capability for the last two (7th and 8th) devices.
    Best regards,
    Bill
