Thread: Another Dumb Question, Shocking After Swimming?
    Jul 2007
    Hillsborough, NC
    525
    There are 3 guys at work who shock after more than 2 or 3 people swim. My opinion is test the FC levels, if they are ok then there is no need to shock. Pool school doesn't say anything about shocking except in reference to clearing up a swamp. So, should shocking after swimming and/or weekly shock be part of my routine?
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    steinholder's Avatar
    Mar 2012
    Wichita, KS
    81
    Re: Another Dumb Question, Shocking After Swimming?
    I usually test in the morning and evening, and add chlorine as needed. There is a daily dosing of chlorine, and adding chlorine "up to shock level".
    22'x52" AG Ultra Frame Intex - 12,500 gal (47K liter)
    Manual Liquid Chlorine - 1HP 100# Hayward sand filter
    Lots of sun, trees, pollen & wind - 50ppm Borates
    4nd season grateful TFP fan
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    I bet those 3 guys at work rely on trichlor pucks, and toss in a bag of "shock" every week, or every time there's some usage. That's the Pool Store way. Maintain your chemistry and you may never need to perform the shock process.
    Give the pool a couple extra ppm before the party starts and a couple more after and it will be fine, assuming everything is balanced.
    toadlife's Avatar
    May 2009
    Lemoore, CA
    57
    Quote Originally Posted by Richard320
    Exactly. Since finding this site three years ago and learning about pool chemistry, I've had to shock my pool precisely zero times.
    21,000 Gallon IG Plaster with Spillover Spa (Built in 1978) | 48 sq/ft Hayward DE Filter | 3.0 HP Pentair Variable Speed Pump | Hayward H250FDN Heater| 8 Gallon Liquidator | Taylor K-2005 | Taylor FAS-DPD Chlorine Test | Taylor "SpeedStir"
    Jul 2007
    Hillsborough, NC
    525
    Ok, that is what I was thinking, and pretty much what I do. I usually do the tests in the AM. I have the SWG running between 2 and 7 PM, that is when the solar heater is most effective so that is when the pump runs. I check chemistry in the AM and FC doesn't seem to drop much. This morning after all the swimming yesterday and me not adding any extra chlorine it was still at 4 PPM, so I thought that was pretty good.
