Thread: correct intex 2650 sand/salt system? model 2012?
    hello guys and gals
    I need some help i got this Intex Krystal Clear 2650 GPH Pool Saltwater System & Sand Filter Pump Set New on ebay they said it was new in box when i got this item back in March 25, 2012 there was no signs it was opened i ordered my pool at the same time 24 ft x 12 ft x52 in Ultra Frame™ Rectangular Pool Set w/ Sand Filter Pump 14 inch was to small from what i read on these forums so i went bigger
    problem is i just got it all setup about 3 weeks ago and been haven trouble with the system not making chlorine to show up on the test strips free chlorine so i started to take it apart to clean it and noticed a screw in one of the nuts attached to the COPPER ELECTRODE HOUSING was like hmm i didnt do that and im thinking this is not the way intex would have done this so i started to look around the net and went back to the intex site ill post links.
    intex site for the 2650 salt system looks just like mine
    http://www.intexcorp.com/index.php/home ... 681eg.html
    ebay site where i got this pump from looks like mine took the pics from intex
    http://www.ebay.com/itm/Intex-Krystal-C ... 266wt_1396
    amazon pics of what i think mine should look like
    http://www.amazon.com/Intex-Krystal-Fil ... B005076RUU
    intex replacement parts section pics shows the model 56681 eg the pic that should be on the main site for intex 2650
    http://www.intexcorp.com/index.php/repl ... 681eg.html
    my model on the pump says its cs20110 on pump and on the sand tub says sf20110 i tried to call intex all lines busy and i haven't sent email to the ebay store yet just want to know before i open a can of worms if im correct in this or not did i get from ebay the correct 2650 sand salt system or not? please all needs some help thanks paul
    Re: correct intex 2650 sand/salt system? model 2012?
    now i dont know who to contact just hooked up my old MODEL 8110 KRYSTAL CLEAR™ DELUXE SALTWATER SYSTEM after the new sand/saltwater system and put it on pump only and the old unit is maken the chlorine just fine tested both put cup in front of outlet then test strip the water in cup new is 0 old system is 1.0 ppm should i talk to ebay or intex about the new system?
    22,551
    You got the right system. Intex changed their system to the one you have. It has the one piece sand filter instead of the two piece.
    You need to contact Intex if it isn't making chlorine. You're gonna need to know what the salt level is along with several other parameters.
