Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Glitch in the Pool Calculator!
    May 2012
    Small midwest town In illinois
    55
    HAHA-- Joke below.
    So I need a target for the following.
    100 Degree weather for over 5 days, and counting. Have not used any solar cover, nor heater (obviously) My pool is almost 90 degrees.
    So with a 10,000 + gallon pool, how many bags of ICE do I need to add, to cool it off?
    Hope you all are enjoying your crystal clear pools!
    14,600g / 24ft. Round Above Ground with Solar Cover and solar heater panel.
    Vinyl Liner
    Hayward Cartridge Filter (CCX 1500RE)
    2 HP Hayward Powerflo LX Pump
    Pool and solar heater get full sun, when its shinning daily!!
    Using test kit: Taylor K-2006
    Successful BBB user.
    Jan 2010
    Randleman,NC
    620
    Re: Glitch in the Pool Calculator!
    Quote Originally Posted by maryj0w
    HAHA-- Joke below.
    Cooling off,,need you a fountain or sprayer do get that pool water in the air.It will cool off some then
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Jul 2009
    Shawnee, Kansas
    92
    I dont know about bags of cubes, but I have been told to use about 10 blocks on my 20,000 gallon pool to drop it 5 degrees. I have never tried it, but have been told it works by folks in Arizona.
    Matt
    20,000 gallon, sand filter, IG vinyl
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    If you search here you'll find that answer
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    As a rough estimate, the pounds of ice required would be (V/1000) * DCD * 43.75
    Where :
    V = Volume of Pool
    DCD = Degrees Cooling Desired
    So..for your 10,000 gallon pool to be cooled 5 degrees:
    10 * 5 * 43.75 = 2187.5 lbs of ice.
    Good luck with that
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by gboulton
    Where :
    V = Volume of Pool
    Good luck with that
    how many recirculated gallons of water 8 degrees below pool temp?!?
    18'x43' Sport Pool
    6,250 gallons need to be cooled by 8 degrees to cool 10,000 gallons by 5 degrees, assuming no other factors affect the temperature in the meantime.
    Use this calculator: http://www.onlineconversion.com/mixing_water.htm
    It does mixing of ice, water and steam! Good luck!
    Josh S
    20.8k gal vinyl kidney; 600sqft surf area, Hayward 1HP Super; 300Lb Sand Filter; Aqua-Rite/T-9; RainbowRay LEDs, Jandy Deck Jets; and a whole 'lotta sweat n time...
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by shep377
    Dang it sums gallons of water mixed! I want to take out water cool it dump it in via fountain, want to know what type of flow I need at x degree temp loss....
    18'x43' Sport Pool
    May 2012
    55
    You all are so much fun here. I think I will just take my daily swims at dusk, and look forward to the 80's they are predicting next week. But if anyone nearby wants to take a dip in a very large hot tub, feel free to stop by.
    Vinyl Liner
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    How'd ya figure that?!?
    18'x43' Sport Pool
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Thanks for the invite, but I have my own down here in Mid TN
    -Gordon
    Quote Originally Posted by harleysilo
    Convert both sides to degree*gallons and solve. Lowering 10,000 gallons by 5 degrees is 50,000 degree*gallons. 50,000 degree*gallons divided by 8 degrees is 6,250 gallons.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Okay. I've been trying to determine if my pool cooler sprays are working, or can work, and if so what is the best trade off, volume of water or amount that it gets chilled. I've collected the water from two different types of sprayes, one was cooling 3-4 degrees, one was cooling 8 degrees. It's difficult to collect the water as i would have to catch all the rain, but i think i could make something to do that without restricting flow.
    I'm starting to wonder if the pool coolers /fountains/pvc with holes in them really do anything or not. My pool uncovered at night can loose 5-6 degrees on it's own. But will gain that right back the next day. The trick would be to catch it at say 92 and keep it from getting hotter with the sprays/fountain/cooler.
    In the above example if your pool cooler cooled 10 gallons a minute you are looking at 10 hours of run time.
    I don't think i'm any where near moving 10 gallons a minute with and 8 degree drop, and i doubt anything else is too. Guess i really need to get an idea of volume of water cooled.
    18'x43' Sport Pool
    If you run the entire output of your pump through the fountain you will be moving much more than 10 GPM. Pumps vary a great deal, but 40 GPM is a much more reasonable starting estimate.
    The home made PVC fountains work, many people have made them and all report noticeable improvements.
    May 2012
    55
    Link to this homemade PVC fountain? I will google, and am considering this "fountain" idea. But it is abnormally HOT here, as we are breaking records. I really don't want to spend a lot as this is the first year I have had a problem.
    Vinyl Liner
    Take a look here, here, or here. Those are optimized for aeration instead of cooling, but the only difference is for cooling you want more time in the air, which just means slightly different aiming of the jets and is otherwise the same.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Jason,
    Each of those shows an IGP. How about doing one on an AGP?
    The two hurdles i can think of right off are:
    1) Would the weight of the PVC filled with water be too much, "prying" on the wall of the pool?
    2) My own AGP...and I presume others...has a "non standard" fitting at the return..that is, it's not a standard plumbing fitting. So how to go about adapting it?
    -Gordon
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    here's an above ground....but i think it's basically the same found-a-use-for-recirculate-on-the-multi-t48380.html
    another
    dane-s-how-to-for-a-quick-easy-pool-cooler-t36086.html
    18'x43' Sport Pool
  20. Back To Top    #20
    I bought this: http://www.amazon.com/Swimline-8598-Flo ... l+fountain
    As much because I need to lower TA as the temp... Mary: Even with this, I'm topping 92/94 I'm not sure where you are, but we can't be that far away... I'm hoping the weekend brings us some much needed relief. I may run the fountain overnight if it's going to drop much. (I'm about 25 min east of STL)
    Vogue Vectra 30' Round (21,200 gallons), Waterway 2HP 2-speed, 27" sand filter - TF100 -- Southern IL - Install 06/2012
    Last minute upgrade from 27' due to error in dealer inventory *yikes*
