Results 1 to 9 of 9
Thread: HELP!!! or is this normal for the pump/motor
    Kannapolis, NC
    89
    I was out by the pool and noticed that the pump,motor cuts off but will start back up on its on. It has never done this or I dont think it has??? Is it the pump or motor as I have a motor I have never used just waiting
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    Feb 2012
    Phoenix, AZ
    728
    Re: HELP!!! or is this normal for the pump/motor
    What type of pump do you have? Is it on a timer?
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Sounds like your pump motor is kicking on and off. This will suck up a lot of electricity so fix it ASAP. Do you have info on the motor? Good luck.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Qwaxalot's Avatar
    Jun 2012
    439
    No it's not normal.
    Likeliest cause is the motor is overheating and the thermal protection is turning it off. Motor cools down and protection lets it start again.
    If the pump otherwise seems to be operating properly, check for obstructions around the cooling vents, pine needles, leaves etc. Clean them all out (you should do this periodically anyway).
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Sorry, for the 2nd username as I couldn't remember password and I am using a work computer, for this reply. I went out to pool and there was a weight in the pump basket that I had put there a while back as my backet is broke and wouldn't stay down. However after taking this weight out I think I may have fixed the problem. Could it be that easy???
    Kannapolis, NC
    89
    Well as I am sure was guessed motor/pump is still shutting off on its on. The motor is extremely hot to the touch. Guess she is overheating a tad, any suggestions since this might entail buying a whole know unit pump and all.
    _________________
    My Pool:
    A bad run capacitor can cause that to happen.
    Qwaxalot's Avatar
    Jun 2012
    439
    Did you try cleaning out the cooling vents?
    Kannapolis, NC
    89
    the cooling vents look clean
    _________________
    My Pool:
