Thread: Painting Fiberglass Steps?
    Feb 2012
    Maryland
    400
    Is it possible to paint the white fiberglass steps?
    I was thinking of having a paint made up that would match with my liner, but wasnt sure if this was possible. Not sure if paint would stick.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Painting Fiberglass Steps?
    I paint them with an epoxy paint when repairing them after I fiberglass them. If you prep the surface properly the epoxy paint should work well. I've only used white so far to match the steps though.
    the epoxy paint is a two part paint. you mix the quart of catalyst with the gallon of paint
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Also bear in mind that having them contrast may save a pet from drowning - or so I'm told. Might be just nonesense.
