Thread: Recommended tool to clean the walls of above ground pool
    Jun 2012
    connecticut
    17
    Anything that you could recommend ? Its gonna be used in a conjunction with hayward aquabug.
    the pool is all resin 24'x54"
    1 1/2 pump + cartridge filter and salt water chlorine gen
    Thank you.
    13k Gal all resin St tropez ABG
    Clean and Clear Pentair filter
    1hp 2 speed hayward matrix pump
    CompuPool CPSC36 SWG
    Build 7/15/12
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Recommended tool to clean the walls of above ground pool
    I have used one of the nylon pool brushes on a pole along with my Aquabug. I also use a simple nylon scrub brush from WalMart that has a hand grip.
    I think it's this one by Hydrotools $6 with Amazon Prime.
    -- Guy --
    Jun 2012
    connecticut
    17
    Ill do that ,
    Thank you for your help.
    Build 7/15/12
