Results 1 to 10 of 10
Thread: Going on Vacation
    Going on Vacation
    Will be on vacation for a week. I hate to ask a friend to stop by and check levels,,,what's the best way to keep your pool chemicals in check when you are away?
    Location - Northeast Indiana
    15,000 Gallons (17x29) Above Ground - 1 HP Sta-Rite Pump - Cartridge Filter - Hayward Aqua Bug pool cleaner- Solar Cover
    TF100 Test Kit
    22,543
    Re: Going on Vacation
    How do you normally chlorinate the pool?
    We use liquid chlorine
    TF100 Test Kit
    22,543
    If your CYA isn't too high I'd buy a couple of floaters and stick them in there unless you have a tablet chlorinator. Also covering it with a winter cover would help.
    coffeegoddss's Avatar
    May 2012
    Minooka, IL
    93
    For vacation, I put the FC at shock level the day we leave. Then I throw a few pucks in the automatic chlorinator (you can use a floater if you don't have one) and make sure the timer is set to turn the pump on and off. Some people throw on their cover or solar blanket but I didn't and came home - 10 days later - to a still clean pool.
    AG, 10,400 gallons, filter cartridge, 2HP pump
    Coffeegoddss...bonafide thread killer!
    POOL SCHOOL...fortheloveofgawd, read POOL SCHOOL
    Great, we have 3" pucks (left overs before TF test kit)... We have never set our pump on a timer, we always pump 24/7. Do most run their pumps less? Would it be best to put the pump on a timer while we are gone?
    TF100 Test Kit
    May 2012
    Minooka, IL
    93
    Pump run time is different for everyone. It's trial and error to see how long you need to run your pump to keep the pool clear. Some people run 24/7 and some run between 6 and 12 hours - depending on what works for them. I run ours for a total of 8 hours a day; broken up into different blocks. Running it all at once or broken up, is also a matter of preference.
    Cutting back would sure save on electricity,,,any suggestions on a timer?
    TF100 Test Kit
    22,543
    Intermatic makes the best timers. If it's 120 volt pump look at the T101, if it's a 240 volt pump look at the T-104.
    Great,,,,,Thanks for all your help
    TF100 Test Kit
