is it ok to vacuum. while shocking?
Jun 23, 2012
55
If I vacuum I will need to replace the water that is removed during the vacuum process. Since we just put the pool in we have alot of dirt that goes into the pool daily. We have not decided what to put around the pool yet. So it is a muddy mess around the pool.
I vacuum mine and return the water to the pool. Only when my pressure goes up do I backwash and send the water to waste. My filter runs 8 - 11 PSI, normally. When it gets any higher it loses suction and that's when I backwash- which isn't often.
