Thread: is it ok to vacuum. while shocking?
    If I vacuum I will need to replace the water that is removed during the vacuum process. Since we just put the pool in we have alot of dirt that goes into the pool daily. We have not decided what to put around the pool yet. So it is a muddy mess around the pool.
    AG 15x30 4 ft deep 12000 gal.
    Aqua Star 100lbs Sand Filter model fs019
    Installed june 2012
    Re: is it ok to vacuum. while shocking?
    I wouldn't do too much vacuuming to waste if you can avoid it. However, it is fine to vacuum normally, in filter mode where the water returns to the pool.
    How often can to vaccum to filter instead of waste. We are on a well and refilling everyday after vacuuming to waste scares me.
    Installed june 2012
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I only vacuum to waste when opening my pool and getting rid of a lot of debris... otherwise, vacuuming on filter is the way to go.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    Aug 2011
    Virginia Beach
    295
    I vacuum mine and return the water to the pool. Only when my pressure goes up do I backwash and send the water to waste. My filter runs 8 - 11 PSI, normally. When it gets any higher it loses suction and that's when I backwash- which isn't often.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
