Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: blowing circuit in amp
    I have yamaha 5.1 stereo amp and outdoor speakers and a six speaker volume control to adjust differnet speakers in the garden but I hook them up they keep shutting down the amp. I know if you do not get the wiring just right it can cause a short. I have done every thing I kow to ensure this doesn't happe but it keeps shutting down the amp. all the speakers are at 8oms. When I use a cheap off the shelf home theater system it works fine and I do not blow the amp. Any sugesstions?
    Jun 2012
    Austin, TX
    48
    Re: blowing circuit in amp
    How did you wire the speakers? If you do more than one speaker off of each output (Daisy chain) your impedance will be lower than what your amp can handle and that will give you problems.
    16.000 US Gal. w/Spa; freeform gunite; built 2015ish; Pentair Quad DE filter; 3 HP Pentair VS Pump; 2 skimmers, 1 main drain, 4 returns, 15 Gallon Stenner Tank, 45MHP2 3GPD Pump, Dolphin Triton Pool Cleaner. TF100 Test kit!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Are the speakers 8 ohms or "8 ohm compatible"?
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Double Check on the back of the receiver-- Most of the Yamaha's had a switch for the 6 or 8 ohm also.. Also might help to get a speaker switch box for the selection of speakers.
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    May 2011
    Orange County, CA
    696
    Sounds like the impedance is not set to 8 ohms or around there. Most non-pro amps will choke if they drop below 4 ohms. Is the volume control supposed to do impedance matching like the ones from OSD? I set up a system using OSD's impedance matching 300W controls and never had trouble with this. Before, I had just run a couple pairs of speakers in parallel and this would cause the HK amp to thermal out at moderate levels. If you have more than one pair of speakers, either get separate amps to drive them, or get impedance matching volume controls. Unless specifically stated, speaker switches don't necessarily do impedance matching either.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    If the speakers are wired in parallel, the resistance (actually, impedence, since it is an AC circuit, but I digress) will be lower than 8 ohms. The resistance of two 8 ohm speakers in parallel is 4 ohms, three parallelled would be 2.666 ohms, and six 8 ohm speakers in parallel would be 1.33 ohms. The actual relationship is Rtotal = 1/(1/R1+1/R2+1/R3...+1/Rn)
    When you wire two 8 ohm speakers in series though, the resistances add, thus two 8 ohm speakers in series would be 16 ohms, etc.
    If you have to connect a few speakers together, they can be arranged in a combination of series and parallel connections to end up with a target overall impedence.
    Thanks for getting back with me I do not bleave I have a switch on the back. I will check more closer. The speakers are wired from the amp into the input of the volome control, each wired seperately for 6 different pairs of speakers. I do know if my niles has OSD. Speakers say eight ohms.
    As mentioned earlier, it's most likely a low impedance problem. If you've got six speakers in parallel it's gonna choke the amp. Even serious professional amps don't do below 2Ohms very well. I try to target my stuff at 4Ohms.
    What length and gauge are your speaker lines? This will also screw up the impedance. The fatter(&shorter) the better.
    I've got a separate amp to control my outside speakers. Still trying to figure out a good output from my Sony though. I'm spoiled by pro gear at work...
    14,000 gallon IG plaster pool, Cartridge Filter
    Come to think of it what niles stuff are you using?
    One other thought.
    Is it for 4/8 Ohm or 70/100V? Huge difference.
    70/100Volt is what you use to hook up a ton of speakers on a long line. Think paging/outdoor sports announceing/etc.
    Looks like my model HTR 6230 has the ohm selection built into the program of the receiver. I have to take a look at the Niles. May be I have to use OSD products. It is a a Niles SSVC-6 speaker selection system. It says it safeguards amp ad receiver. 100 watts and a selectable impedance magnification for up to 6 pairs of speakers.
    May 2011
    Orange County, CA
    696
    Sorry, OSD=Outdoor Speaker Depot, just one of several vendors for speaker level controls that have impedance matching. Lowes sells the OnQ version (that does impedance matching, but is quite a bit more expensive). The point is that these need to be properly wired to maintain a load that does not dip too low below 8 ohms, as doing so will cause the amp to clip and then overheat. The ones I prefer to use have transformers instead of variable resistors, and have a fairly clean frequency response. If wired correctly, you can one or a dozen pairs of speakers connected to a single amplifier (though a dozen would not make much sense).
    I sat down last night and tried it with just 1 pair speakers and it keeps tripping the circuit in the receiver. In all honesty I bought this at radio sahck they repaired it and I got it home and it woudn't turn ou so they traded it out for a new one. that was last summer. So I haven't tried to use it i a year. I was using a cheap home theater system that was using out in the yard and was working great until stopped working on the cable TV side, workig great for a five disk CD changer. So I'm interested in a amp that has a tanformer in them. I do have an old yamaha receiver I may try that one and see if that one will work for my applicaion.
    May 2011
    Orange County, CA
    696
    Old Yamahas are great. They really knew how to build good amplifiers using monolithic op amps. Now, they are just like the rest, more concerned about video than audio. But, the old ones are built like tanks and usually sound great. It might require some de-oxing of the pots and switches, but I'd recommend you use that in a heartbeat.
    I bought it at a flea market I will try it and see if that will suit my needs. I do not know how old it is. I have to correct that, it is a sansui A7 amp. I thought it was a old Yamaha. I have had the black face series Sansui I got in Guam when I was stsayined there.
    But it doesn't have the inputs like the yamaha How wuld I connect them if I wanted use it with the yamaha, assuming I can keep it from blowing circuits.
    I have the Sansui 7 and I hooked to a pair of speakers and are work ing fine so far. I put the TEAC 5 disc changer into the tuner input and then took the out put of audio on the digital cable box and put it into the AUX of the AMP. I will hook up the other five pairs of spears to the Niles later. I like the simplicity of the Sansui Amp, it has adjustments like balance, Bass and trebble and left and right chanel. I can crank the volume with out blowing a circuit.
    May 2011
    Orange County, CA
    696
    The only input that won't work on that Sansui amp (also a good solid brand) would be the phono input. They are a different impedance than other inputs, and have an RIAA equalization curve designed for LP playback on a turntable. You should be able to source a 1/8 to RCA cable to connect up an iPod or MP3 player if needed.
    Well the sansui A7 blew fuse I put a new one in and it imediately blew again. I'm back to using my surrond sound amp which is working fine. It is a cheap insignia.
    May 2011
    Orange County, CA
    696
    Hmm. Maybe the Sansui bit the dust? Did it blow the fuse when all of the speakers were loaded up on it, or with a single pair. Have you tried a different pair of speakers with different wires on the Sansui? Could be some bad speaker wiring somewhere.
  20. Back To Top    #20
    I will put another fuse in it and disconnect all the speakers and see if it has a problem then. It worked for for 2 days and I put in another fuse and then it blew right away.
    Maybe some one post what kind of setup they have. I have 2 pair deck speakers that are 8 oms Auvo speakers and I have 4 pairs of rock speakers at 8 oms and using 14 guage direct burial wire in the yard and outdoor speaker wire on the deck.
