Results 1 to 7 of 7
Thread: Sand bag for ladder had a leak ...
    Apr 2009
    South Texas
    177
    I replaced the sand sacks that came with the pool with plastic jugs full of sand. But I cant get rid of the sand that keeps settling on the bottom. My readings are great and my pool is sparkling thanks to following BBB. So those little whisps of sand stick out like a sore thumb and are driving me nuts. I vacuum it up and as soon as I have to backwash it's back. I rinse after backwashing. But as soon as I switch back to filter I see it coming out of the jet. What can I do? Should I backwash and rinse longer? I feel like I'm emptying the pool. Obviously I'm doing something wrong. I know one of your brilliant minds and experience can help me. Thank you!
    Just bought a new house in the country, no pool yet. :(
    Hot tub..500 gals..bromine
    TF100 test kit and speedstir
    wetchem's Avatar
    May 2012
    Somewhere in the middle of Nebraska
    208
    Re: Sand bag for ladder had a leak ...
    Is this the same type of sand that you would have in your sand filter?
    Intex Ultraframe 14'x3.5-Round (4000ish-gal) AG - Vinyl - Intex 5667EG Sand Filter 1600gph :)
    ( retired: 637R Crtrge 1000gph someday it may have another life as a water fountain... or feet washer! Solar Water Heater? )
    :mrgreen: Click here to Goto Pool School. :scratch: How Much Of What? Click Here - Poolcalculator.com :lookhere: TestKits
    Apr 2009
    South Texas
    177
    I have no clue. They put the sand in the filter and gave me the bags to hold down the ladder when they installed the pool. This looks like regular old sand, like what went under the pool. It's rather brown, but that's cuz it's wet.
    wetchem's Avatar
    May 2012
    208
    I'm going to leave this for people with more knowledge about your system.
    I would guess that something didn't get seated properly in your filter - but that is only a guess. Depending on how long ago "they" were that installed the filter, I would call them and tell them that you have sand coming out of the return and ask them to come fix the problem. A good installer will stand by their work... word of mouth is the best advertising... and the worst too!
    -wc
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    A lot of us are having problems with silt being returned to the pool after vacuuming... I am one of them. First be sure that it is in fact sand and not silt. The silt will just disappear in a little puff when disturbed. The sand will just move a little bit, and of course, it will feel gritty. My daughter dumped a bit of sand from my steps the other day and I just vacuumed it up with two skimmer socks in my skimmer basket and that took care of the sand. The skimmer socks have also helped immensely with my silt problem.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    22,548
    Tie a thick sock over the return and let the pump run a while. If you don't see any sand getting into the sock, backwash and rinse like you normally do and see if it gets sand in it then. If it does it after a backwash it's likely the multiports spider gasket.
    You are shutting the pump off when changing positions on the multiport valve aren't you?
    Apr 2009
    South Texas
    177
    The whole thing is 2 weeks old. Yes, I turn off the pump when switching settings. I will try the sock thing when I get home from work. Thx.
