Results 1 to 7 of 7
Thread: timer for dual speed hayward
    I'm looking for a timer recommendation for use with a hayward dual speed super pump.
    An intermatic timer would work best. They come in analog and digital. Here is a list from a online pool store. Just make sure you get a weatherproof box if it will be outside.
    http://www.inyopools.com/controls_intermatic.aspx
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    22,542
    Re: timer for dual speed hayward
    As Kyle said, it's hard to beat the Intermatics.
    If you have a 230 volt pump the T104/T106 combo is a good mechanical unit. Or the P1353ME is a good if you have either a 115 or 230 volt pump.
    ok, still going around on the timer with the pb. He says he typcially uses the 01200 box but the problem is that's not for a dual speed pump. Can he still use that box but swap out the inside of the box with something that will conrol the dual speed pump? Or should I just manually switch the pump when I need to and not worrry about a timer that controls both speeds? Someone mentioned the T004/T106 combo. Is this either the 104 or 106 or are the used together. This is mostly greek to me so any help is greatly appreciated Again, I have the hayward dual speed super pump 1.5hp a separate polars pump, light and SWG.
    In most situations it works well to use a standard timer and have a manual switch to change speeds. Unless you have a specific reason to need to be able to run at different speeds at different times of day there isn't anything to be gained by getting a two speed pump capable timer.
    The 104/106 are used together, one controlling on/off and the other controlling high/low speed.
    Jason
    So if the pb is used to doing one speed pumps and using the 01200 box and timer for single spped then just go with that and flip the switch on the back of the pump when I want to change speeds?
    38,246
    That is what I do .... until I get my Pro Logic.
