I just want to give you some input on your filtering. I'm no expert so you can take this with a grain of salt!! I have used the pump/filter system that you have there. I too have quite a few kids that swim in my pool (neighbors) along with my own two children. With that much traffic, that pump and filter cannot keep up. I would certainly recommend the sand filter in the link posted above. However, the pictured filter I believe is the 1600 gph filter, so you might wanna be sure before ordering. That being said, the 2650 gph sand filter normally comes with a 16" sand filter, and the one pictured is (I think) a 14 inch. My pool is 8000 gallons and I have the 2650 gph pump and 16" filter. A buddy of mine has the same size pool as me and he has the 1600 gph pump and 14" sand filter system. His works absolutely fine. If money is an issue, get the cheaper. I have another friend with the same pool as me, and he has an even smaller sand filter. His water is sparkling as well. The only difference you will find is you may have to backwash a little more often with a smaller filter. So in summary, the stock pump/filter that comes with any of the Intex pools is not sufficient to clear a pool with a high bather load. I think your pool just might clear up with a sand filter. I had trouble with the multiport valve on my pool this year soon after setting up my pool. So I was running only the stock pump and cartridge filter. My water was testing for good chlorine levels, but just would not come clear. After getting my sand filter up and running again, my water was sparkling again within a couple of days. So I think your best investment at this time would be to buy a sand filter.
You also asked about a salt water generator. You don't need one. It's just another way to add chlorine. It's nice and convenient, but not necessary especially if you're around every day to add bleach to your pool. It's something that you can get down the road when funds allow. But spring for the sand filter as soon as you can.
GC
GC
