Thread: Should I test the water from the hose or wait 4 full pool?
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Our pool should be in and ready for water no later than Wedenday/Thursday. My question is should I test the water from the hose or just wait until the pool is full and then test or do both?
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    It's not a bad idea to test your tap water for pH, TA and Hardness before you fill. Then you'll know which direction you'll be moving pH so you'll know what to have on hand. IF CH or TA are way out of range, you might need to find alternative fill water.
    30,401
    Yep, test the fill water. Post your results up on the forum and you'll get lots of good advice. You'll be ready to adjust your pool from day one!
