Thread: I'm not understanding the Pool Calculator.
    CarolJ's Avatar
    Jun 2012
    Rockford, IL
    15
    Intek Pool Owner-10'x30" for grandbabies. Starting small before going big! 530 gallon pump w/type A filter.
    22,543
    Re: Turning Your Green Swamp Back into a Sparkling Oasis
    There's an article in pool school on how to use it. But basically you put your test results in the now column and what you'd like the numbers to be in the target column. Be sure to put your pool size in the top cell.
    At the bottom you should select vinyl, bleach & TFP levels.
