Thread: How to raise TA?
    Oct 2010
    michigan
    284
    How to raise TA?
    I use muriatic acid to lower PH, overtime my TA is starting to get too low. so i just use baking soda to raise the TA up? and continue to use muriatic acid to lower the PH?
    seems like they are just fighting each other, but i assume the baking soda adds more TA than PH.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: How to raise TA?
    Yes, and yes.
    What are you letting the pH get to, and what are you lowering it to? Some pools find their sweet spot at 7.7-7.8, so it could be that you were getting a little too aggressive in keeping the pH down.
    Oct 2010
    michigan
    284
    running a 7.2- 7.4 PH to keep the staining off the fiberglass wall.
    Mar 2011
    Sunny Central Florida
    91
    I run 7.2-7.4 as well, and I just added baking soda to my pool. Got TA up to 100 from 60. PH is staying lower now, how I like it The baking soda didn't change my PH at all.
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by smooth2222
    What kind of staining?
    In short, 7.2 is very aggressive for pH maintenance. Most people keep it in the 7.6-7.8 range. That said, there are "chemistry reasons" to keep it that low, and if you're in that boat, the TA additions will be a frustrating byproduct.
    Oct 2010
    michigan
    284
    took my TA from 80 to 100, will slowly go back down as i add MA to lower the PH when it rises again.
    lower PH 7.2-7.5 will help keep the staining off the fiberglass.
