Thread: Intex CS8111 SWG stops making chlorine towards end of cycle
    We have had our new Intex Ultra Frame 16' x 48" pool up for about 3 weeks, and so far all of our water tests have been good and the water is clear. We have been running the saltwater chlorinator for about 4 hours each day, and I have noticed that towards the end of each chlorination cycle (maybe for about the last half hour) that the chlorinator does not seem to be producing any more chlorine (i.e. can't see any bubbles being formed in the clear tube). It doesn't seem to matter what amount of time we set the chlorinator to run (2, 4 8 hours) it always seems to stop producing chlorine towards the end of the cycle. Is this normal, or is there something wrong with the SWG? Our salt level is about 3200 ppm, and we consistently get a FC reading of about 2 ppm. Has anyone else observed this with their Intex Krystal Clear SWG?
    Oct 2011
    New Caney, Texas
    414
    Re: Intex CS8111 SWG stops making chlorine towards end of cy
    The the pump runs about 15 minutes before the chlorination starts then the chlorination shuts down about 10-15 minutes before the pump shuts off.
    This is normal.
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Mine appears to no longer be producing chlorine about the last 30 mins of the cycle either. Been that way from day one so I wouldn't stress over it. It's probably designed that way as stated above.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Thanks so much for your responses. I am glad that this behavior appears to be normal and is nothing to be concerned about. Thanks again.
