Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Aboveground pool bonding
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    How do I know if my pool is bonded? And is it required for an above ground pool?
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    22,539
    Re: Aboveground pool bonding
    There should be a large bare wire connected to the pool wall and to every metallic piece of equipment associated with the pool water. One at the pump should be obvious.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    All AGP's are supposed to be bonded.
    Attach #6 (or 8, depending on where you live) solid copper wire to one of the wall lugs (the ones that connect the 2 ends to each other) and run the line back to your pump, there should be a bonding lug on the pump. The line should be +- 6 inches in the ground.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    The water should be bonded too so see if there is any metal in contact with the water either in the skimmer or the plumbing and then to the pool and the pump as stated above. Should be a "halo" around the pool 18-24 inches away from the pool about 4-6 inches deep. It should be a 8 gauge bare copper wire.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    So the halo bonds the water correct?
    Installed May 2011
    BBB method
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    The halo goes around the pool and bonds to atleast 4 legs (metal) which also bonds it to the frame, then it goes to the pump lug and then to the water. Anything else that you have attached to the pool that is metal like steps needs to be in the loop too. The excess wire is coiled into a 18-24" coil and buried under 4-6 inches of soil 18-24" from the pool and pump.
    Sep 2011
    Omaha, NE
    95
    Quote Originally Posted by poolmama67
    No, the halo just surrounds the pool to "collect" any stray voltage in the ground. The water its-self need to be bonded by introducing a piece of metal that is a minimum of 9sq inches, and then that is connect to the rest of the boding wire.
    Here is an example of a device to bond the water. There are a few ways this can be done.
    http://www.acehardwaresuperstore.com/17 ... onding+kit
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    ^that is the same place I bought mine. best price on the internet.
    Bonding the water can be done a couple of ways. You need atleast 9 sq inches of metal in contact with the water at all times. The Brundy waterbug is a stainless plate that goes in the skimmer and bonds it. There are also metal pipe nipples that have the required metal contact too. I am building an AGP now and will be bonding it myself. I should be free to start that this coming week. When I do I will make a tutorial and post it.
    Here is my build thread. It has pics of the brundy waterbug and the needed parts to bond.
    18x34-doughboy-agp-autumn-breeze-new-pics-t46193.html
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    My steps are plastic and pvc. I am going to post of pic of the side of pool with a full sheet of metal. Is this a bonding piece? Is this not something that should have came with the pool?
    Installed May 2011
    BBB method
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    No, they don't come with the pool. If it's not a bare copper wire it's probably not the bonding.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Ok, now that I am home and can see it, are you referring to the metal panel the skimmer and return are mounted in? If so, then no, that is not part of the bonding.
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    They never said anything about bonding the pool. I will be ordering the suggested bonding piece. When it arrives I am sure I will have more questions about installing it.
    Installed May 2011
    BBB method
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    My installer told me it wasn't necessary. But my city code says its mandatory. Go figure.
    The rules for bonding above ground pools vary from place to place. In-ground pools essentially always need to be bonded, but some regions count most above ground pools as temporary and don't require bonding. Bonding is a good idea regardless.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    ^always good advice. It's a safety thing regardless of requirements and safety is never a mistake.
    Just a friendly warning about Acehardwaresuperstore, these guys will charge your credit card instantly for whatever you buy and they are in no way associated with Ace Hardware. I had placed an order for the water bonding kit listed above and could never get anyone on the phone to check on when it might ship. They also have a very bad reputation of running a bait and switch on shipping charges. I was finally able to get a response through email and hopefully cancelled my order.
    I'm not trying to blast the company because I know several on this board have used them successfully. Please check their facebook page(accessible through their website) and also resellerratings.com to see some of the comments that others have made about their shopping experiences with this company.
    Just want to give everyone a heads up on what I found
    24 Ft Sharkline Matrix , ~15,200 Gallons
    Pentair SD60 w/ 2 speed 1.5 HP Dynamo pump
    Taylor K-2006 --- BBB
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Wow, sorry to hear that. It did take a long time to get mine but I ordered it way in advance (unbeknownst to me at the time) so I never really paid attention to the time. Did you finally get one?
    Quote Originally Posted by Glock
    Found one on Amazon and it should be here tomorrow, hate to say anything negative but just want people to be aware of what has happened to others.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    No worries. Good to hear you got yours. You know, I used to make parts like the Brundy Waterbug for cars. I could make these things stupid easy. Too bad there isn't a higher demand for them. See a need, fill a need! lol
  20. Back To Top    #20
    May 2012
    Montville NJ
    545
    Codes - whatever that code may be - is a MINIMUM. If somone "builds to code" they are building to the bare minimum of safety standards.
    Always better to go above and beyond. Having said that, I doubt my ABG has a ground halo - having seen how the previous ownner did electrical work in this house. I do have a ground rod and have been bonding things to that though.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
