Results 1 to 8 of 8
Thread: CC Question, VERY HOT Weather TEMPS HERE!
    May 2012
    Small midwest town In illinois
    55
    We have been in over the 100's for a few days and it looks to be hear for at least the remainder of the week. Pretty much Full sun all day.
    I am now having to test my FC - 3 times a day (morning, afternoon, and night) Because of evaporation, MY CYA fell, and I am now adding more. I am only losing 1ppm FC over night, But come 2 in the afternoon, I am at 2.5 FC. ( I know this will get better after the CYA takes effect) I have my goal at 5.5 since it has been hot and sunny.
    My CC question is I just checked it and it read .5 (Turned very light pink, and only took one drop to go clear.)
    Should I remain on the course I am doing, or bring my FC levels up? I can not put my cover on, as I want a cool pool, not a spa, lol.
    TBH its so hot and miserable out there we are only swimming at dusk
    14,600g / 24ft. Round Above Ground with Solar Cover and solar heater panel.
    Vinyl Liner
    Hayward Cartridge Filter (CCX 1500RE)
    2 HP Hayward Powerflo LX Pump
    Pool and solar heater get full sun, when its shinning daily!!
    Using test kit: Taylor K-2006
    Successful BBB user.
    38,475
    Re: CC Question, VERY HOT Weather TEMPS HERE!
    CYA does not drop due to evaporation.
    Sounds like you need to target a higher level for FC if it is dropping to low.
    Post up a full set of test results.
    typical pools lose about 2-4ppm of FC everyday.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    May 2012
    55
    Confused, as If I am having to add water too my pool, therefore, I am loosing water. Unless, I am wrong the only way to lose CYA is to lose water in your pool? Adding water due to the kids splashing it all out, lol. I misspoke about the evaporation. Its the heat making me CRAZY
    This Am I was at
    FC-4.5
    PH- 7.5
    CYA- 25
    (i dont check my CYA, unless I notice a drop in FC, as I just did)
    Added CYA to get to 50 according to pool calculator, along with bleach to get to 5.5 That was about 9 this morning.
    Tested again at 2
    FC was 2.5 (added bleach)
    Can't test CYA just yet, as that take time to register.
    Tested CC was .5
    We are in a drought, no such luck for some free rain waters...
    Vinyl Liner
    May 2012
    55
    PS my target FC is 5.5
    This is the first time this summer, I have encountered an issue.
    Vinyl Liner
    38,475
    Your CYA will only go down by actively removing water (splashout, filter clean, etc) not by evaporation.
    More important than the "target" FC is the MINIMUM FC level for you CYA level.
    CYA of 25ppm, the minimum is 2 ppm FC now that you have added CYA to reach 50ppm, your minimum is 4ppm FC.
    You have to add enough FC such that it will not drop below that number before the next time you test and add.
    I am really unclear about what your actual problem is. If the CC clears with 1 drop ... then you can ignore it. IF the CC climbed up to 1ppm or higher, then there would be reason to be concerned.
    Likely you were loosing more FC to the sun than anything else since your CYA was so low.
    May 2012
    55
    I agree, I am a newb, and completely forgot that every time I was filling my pool from the kids, I was losing CYA. (which was everyday this week, and some last weekend) and with this Heat and sun, it just all caught up to me.
    So getting my CYA back to 50,
    with a FC target at 4, but to be honest when I know its going to be hot and sunny, with the kids in the pool all day I do add a bit more bleach in the morning. Nothing to major tho.
    Until then I will just keep making sure I maintain a good FC level by checking it more often. Yes spending a bit more on bleach, but better than getting cruddy waters.
    Vinyl Liner
    38,475
    No.
    Your MINIMUM is 4ppm. You should target about 8ppm to make sure our never drops below 4ppm.
    May 2011
    Clearwater, FL.
    446
    Hi maryj0w,
    I'll also say your very close to same situation as I'm in...
    See my post here:
    opinions-please-on-my-new-pool-about-fc-usage-t49083.html
    Go higher on both CYA and higher with chlorine high side.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
