Results 1 to 13 of 13
Thread: How Many Chlorine Pucks to Put in at Once?
    Happy Independence Day to the US. Just did another full test today. These are are the results:
    FC 2.5 ppm
    CC 0.5 ppm
    TC .03 ppm
    TA = 160
    CH = 300
    CYA 70
    pH 7.8
    The FC seemed low, so I put in a 3" chlorine puck in the floating chlorine dispenser. Should I put in more than one puck at a time? The pool guy usually put in four per week in the dispenser, but he only checked the pool once per week. Since I'm here, I can check more frequently. This is my first week going solo and taking care of the pool myself.
    I understand the pucks are bad because they cause CYA to accumulate. Unfortunately, I just bought an 25 pound bucket. I haven't opened it yet, so I guess I could send it back, but shipping will cost a fortune. I think I'll try to use it up and then switch to the liquid bleach method.
    Finally, the pH is high, so I guess I should also add more muriatic acid as well.
    Sand filter, in ground pool, plaster bottom, Hayward Max-Flo II pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: How Many Chlorine Pucks to Put in at Once?
    None.
    CYA is already 70!! You don't give pool size, but just for argument, call it 20,000 gallons. That's a good-sized pool. If you add 25 pounds of trichlor, you will raise CYA by 83!!! If your pool is smaller, that will go up even more.
    The pucks will keep for a long, long time. Save them for when you go out of town.
    You need bleach.
    Have you read Pool School?
    30,408
    Yep, None for all the reasons listed above.
    I'm not sure how many gallons the pool is. It's odd-shaped and of varying depth, so it's hard to calculate the volume. I understand your point. I guess I will stop at Walmart and pick up some 6% bleach. Thanks for the replies.
    38,262
    Post a picture and dimensions and we can help you estimates the volume.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    This is embarrassing. Now everyone can see what an ugly pool and yard I have. The pool is about 6 feet deep in the middle. The max width dimension is about 17 or 20 feet. Lengthwise, it must be around 30 to 35 feet. The wide section up to the island portion is probably about 25 feet long and the island adds another 8 feet. The water around the island is shallow. That is where you're supposed to step into the pool and then it gradually becomes deeper as you walk towards the center.
    The spa portion is about 5 feet by 8 feet.
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Hmmm.... I wish I had an 'ugly' pool like yours!
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    May 2011
    Clearwater, FL.
    446
    No Ugly there!
    I got a lot of dirt I'm working on after a new install of a 21' round buried 14" and 6'ft deep center, did I say LOTS of dirt!
    The only ugly you could possibly have is to not listen to the advice given by some of the best here on this forum!
    P.S. Use bleach or liquid chlorine.
    pH could be adjusted down to 7.2 to help lower you TA.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Awesome pool! Love the island!
    Now is it just the pic or is the water a little cloudy? This place will fix that for you!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Mar 2011
    Sunny Central Florida
    91
    Yeah, put the bucket of pucks in the shed. They will keep. You don't want your CYA higher.....start using liquid bleach, then you can use up the pucks when your CYA goes down (I was on bleach for a year or so before I started using pucks again.)
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    Smykowski's Avatar
    Sep 2011
    3,065
    I read the title of this thread, and I wanted to immediately post NONE. However, like always, you immediately got great advice, so I'll have to come up with something else of value to say. Here it is:
    Pucks aren't evil, even though by reading a lot of the posts here you might think so. They're just not for everyday use. Vacations only, and that's only if you understand what they're doing to your water.
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by Chaika
    You're gonna need to drag out a tape measure to get more accurate dimensions. Accurate to within 2 inches, not 5 feet!
    And stop apologizing for the look - this is the BEFORE picture!
    Thanks everyone. My tape measure died trying to measure that pool. Refused to retract after I did a couple of measurements. Might have been because I got some water in it a few weeks ago trying to measure the diameter of some pvc pipe in the pool. Yes, the pool water does look a little cloudy in the photo. I may have dialed the pump far too back. It was also a rare cloudy day here when I took the photo. It actually rained.
