Results 1 to 9 of 9
Thread: Instant Chlorine?
    May 2011
    Wilmington, N.C.
    45
    Instant Chlorine?
    Has anyone heard of or tried this product?
    http://www.intheswim.com/Pool-Chemicals ... -Chlorine/
    I don't have anything to do with this company. I received a flyer and was just courious. Thanks
    Pool size- 24 ft Round. 13500 gal Above Ground. Filter- Sand 25 GPM, Pump- 1.5 HP/ 70 GPM.
    K2006 FAS-DPD Test Kit.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Instant Chlorine?
    I don't see the MSDS, but since the directions say it is granuals (& broadcast & brush, etc), my guess is that it is dichlor or possibly trichlor -just repackaged and renamed.
    Someone will find the MSDS for us.
    You're done SLAMing when:
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I did a search on it and could not find out the exact ingredients but it appears to be a weakened chlorinating product in a powdered form. It may or may not be a trichlor/dichlor product, but it cannot be used to shock a pool since it does not apparently have enough sanitizing properties to do that - only to lightly maintain an already balanced pool. The reviews found at other sites pretty uniformly state that it will maintain an already balanced pool if it is added continuously but could not rectify an algae bloom or drifting FC issues. The product name is owned by Cortz, Inc., which owns In the Swim. I could find no MSDS on the product.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by Butterfly
    I'm not having any luck finding an MSDS. They're rather secretive.
    It's going to be either Dichlor or Cal-hypo.
    EDIT: Cal-hypo http://i.poolproducts.com/pdf/Y7700-manual.pdf
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    I just called them...........they are emailing me a MSDS on it. Will post it up shortly hopefully!
    Apr 2010
    East Texas
    9,643
    There ya' go......................
    Attached Files Attached Files
    They have a fairly wide range on the cal-hypo percentage, 60% to 80%.
    Apr 2010
    East Texas
    9,643
    Would this be worth the effort for a friend to use while we're gone on vacation for a week? Beats them having to handle liquid bleach. My calcium level is only 50 or 60ish. Or is regular cal-hypo cheaper/better? I've never priced/used it.
    Regular cal-hypo is cheaper. Easier is debatable, they are both very easy. Given your CH level is that low, adding a little calcium is just fine.
