Thread: Water looks cloudy at night when light is on??
    This is our first year as AG pool owners...so far so good...our water has looked pretty clear for the most part except at night it looks a little cloudy right in front of the light. You can see teeny tiny little "partlicles" floating around. I added clarifier yesterday per the pool store's advice & we vacuumed (can't really tell any difference)...We have a SWG but I went ahead & added 1lb of cal hypo shock this evening since we've had alot of dirt/pollen/leaves in the pool & alot of swimmers. My question is...does the water normally look like this @ night with the light on? And if not could it be due to the dirt & pollen?? Thanks!!
    24' x 52" AGP round...1.5 hp Hayward & sand filter...Aquatrol...Located in SE KY
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Water looks cloudy at night when light is on??
    Nighttime obviously is the easiest time to see debris and all pool's have it to some degree.
    It could be that your pump is oversized for you filter. What filter do you have? Post the model number or post a pic of the label on the side of the filter. Also post what model pump (not just the motor) you have.
    Be careful with the cal-hypo, it adds calcium along with chlorine. Do you know your current CH level?
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Quote Originally Posted by linen
    I thought CH was not a worry with an AGP?
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by elwood58
    Low CH is not, but high CH can still cause scale on vinyl liners and cloudy water. Also, the op has a swg where scale build up could prevent chlorine production.
