Thread: Get filter basket out of jacuzzi magnum force
    Jun 2012
    Barrie, Ontario, Canada
    28
    Hi everyone.
    I am wondering if anyone has a jacuzzi magnum force pump and if so how do you get the **** filter basket out to clean it?
    Thanks!
    Size - 50,000 Litres / 13,208 g (32' x 16' x 4.5' Sport Pool)
    Filter - Jandy CL460 Cartridge Filter
    Salt Water - Zodiak LM2
    Pump - Jacuzzi Magnum Force
    Heater - Laars LT LT250NS-C
    IG Pool (Vinyl)
    2003-2005 ish
    Sep 2007
    Central NJ
    59
    Re: Get filter basket out of jacuzzi magnum force
    I had a Jacuzzi Magnum pump for 16 seasons before this year.
    Not sure I really understand your question since removing the filter basket is rather straight forward -- turn off the pump,un-screw the cover for the filter basket, then pick-up the filter basket. Are you not able to un-screw the filter basket cover? Not able to pull the filter basket out of the pump?
    Jun 2012
    28
    The plastic cover comes off fine, but the basket doesn't come out. It has a flapper on it that looks like its attached to the basket itself, but I try and pull it out, it doesn't come. I try to pry around the edges, doesn't help. I tried turning it (as if it would unscrew) but doesn't move.
    IG Pool (Vinyl)
    2003-2005 ish
    Sep 2007
    Central NJ
    59
    Don't be afraid to give the plastic basket a good tug. If its caked with pool ****, it might take a little extra pull. Sometimes I'd feel resistance (almost like suction holding it in place).
    Don't pull by the flapper or it will tear off from its attached 'ears'.
