Results 1 to 7 of 7
Thread: Lo N Slo or
    Apr 2012
    South Dakota
    87
    Lo N Slo or
    TA is high but the Pool Calculator states to lower the PH even though it is whithin range but I am no sure what to add to lower. It Add 17 oz by weight or 15oz by volume of washing soda or soda ash or add or add 33oz by weight or 32oz by volume of borax.
    I have some Lo n Slo and Dry Acid which I guess is the same thing.
    PH 7.4
    TA 190
    CH 350
    Chlorine 5
    Cyanuric Acid Test 50
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    38,284
    Re: Lo N Slo or
    There is no reason to actively lower your TA unless your pH is rising faster than you like.
    If you really want to lower it (although I see no reason to): Lowering Total Alkalinity
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Lo N Slo or
    Unless you having problems, I wouldn't do anything now. Ph should drift up since you have high TA, then when it get's to 7.8 dose to bring it down to 7.2 at the same time is will lower you TA a little. You will repeat this many times and at some point your ph will become more stable.
    Apr 2012
    South Dakota
    87
    Re: Lo N Slo or
    The water could be a little clearer but it is good enough if it is recommended that I don't add anything.
    Thanks.
    Vinyl liner
    Taylor K-2006
    38,284
    Re: Lo N Slo or
    TA should not affect the water clarity.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Lo N Slo or
    What are your FC and CC levels?
    Apr 2012
    South Dakota
    87
    Re: Lo N Slo or
    FC 5
    CC .6
    Vinyl liner
    Taylor K-2006
