Thread: not a newcomer but i cant get rid of my cloudy water!!
    Jul 2011
    central new york
    7
    ok so i have had my pool for a long time however, i replaced my liner this year. i had my pool clear as can be when i opened it.. then i developed an air leak that kept making my water cloudy.. jasonlion helped me there.. now although all my chemicals are in acceptable levels i cannot get my water clear again.. im dying over here.. its not green, just cloudy, clarifier didnt help so im kinda stuck.. just to let anyone reading know, i have just shocked my pool and added stabilizer so i dont know if that makes a difference.
    25,000 gal - IG - vinyl - 300lb sand filter - 1h pump.
    38,516
    Re: not a newcomer but i cant get rid of my cloudy water!!
    What did you use to "shock" your pool?
    Post up a full set of test results ... you know the drill
    Jul 2011
    central new york
    7
    i took my water to the pool store and they didnt give me exact results but they said everything was perfect except stabilizer so i added 4 lbs.. sorry. i used 5 gals liquid shock.
    38,516
    I find it hard to believe that JasonLion did not have you get a good test kit ... that is the only way to truly take control.
    See my signature for the recommended test kits.
    So , what was wrong with the stabilizer according to them (realizing that it is one of the test the pool stores are the worst at)
    38,516
    BTW, 5 gallons of 10% would have raised your FC by 14ppm and 12.5% would have raised it by 18ppm.
    If your CYA is above 40ppm, you did not even get up to shock level.
    Review: Shocking Your Pool
    Butterfly's Avatar
    South Carolina
    10,045
    Post a full set of test results and tell us how you got them
    Test results, test results, test resluts.
    You're done SLAMing when:
