Results 1 to 9 of 9
Thread: Vinyl liner coming off again
    The liner is coming off in the same locations as last year. How do I fix this so it stays?
    16x32 inground vinyl pool
    Hayward sand filter
    Hayward 2 hp super pump
    38,301
    Re: Vinyl liner coming off again
    I do not see any posts from you from last year. So, I have no idea what you are talking about.
    Post up some pictures and more info.
    Jason I'm still trying to figure out how to post a picture. It's coming off just below the coping where it clips on to the side.
    Hayward sand filter
    38,301
    Re: Vinyl liner coming off again pic
    Hayward sand filter
    hairdryer or boiling water to soften liner, use liner lock i have stuck in a popcicle stick as a quick fix. Be careful with electric around the pool and dont make it too hot with the dryer....
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    heat siphon heat pump
    What can I use to prevent this from coming off again? I can't be the only one with this problem. I have used the hot water method. But it is too hard on my hands, so isn't there a tool to use?
    Hayward sand filter
    No tool, just brute strength. I used to have this problem every now and again and was always able to fix it myself by lowering the pool a bit and using muscle and hot water. This year, I had it happen in 2 pretty large areas and no matter how hard I pulled, and how much hot water I used, I could barely get an inch back in the track in over an hour. I had to call the dreaded "pool guy" to come and fix it $$. They (2 beefy fellows) lowered the pool (multiple times) almost to the floor in the shallow end and finally got it done in almost two hours. I'm getting weaker as I age!! Once it gets back in, place "liner-lock" in the bead to keep the liner in place. http://www.amazon.com/Liner-Lock-Beaded ... B004WJMR2O
    Good luck!
    Gerry
    Pool: 25,000 gal.(appx.)/IG/Vinyl/DE
    1.5 HP superpump / Filter Flow Rate - 72gpm (as per spec.)
    Hayward 300,000 BTU natural gas heater / Polaris 380
    Long Island, NY
    Thanks for your help Gerry. The only thing I don't understand is how the bead lock is applied.
    PS I think I have a good idea for a tool.
    Hayward sand filter
