Thread: Sunlight vs Daylight bulb
    Apr 2012
    South Dakota
    87
    When using a test kit is it best to be outdoors to get good test results from sunlight or a daylight bulb inside?
    Last week I did some testing of PH outside and inside and the color was a little different in doors. PH seemed a light red vs indoors using a daylight where it was a little darker red.
    Thoughts? Opintions?
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Sunlight vs Daylight bulb
    I would guess the daylight bulb will give you more consistent results.
