Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: New to BBB I have a question.
    I have had my CYA checked and it is at 53 ppm. I have dropped the water level to try to get it at 50 or just below. I live in Arkansas so I have tons of sunlight.
    What is the recomended level of CYA in high sunlight area?
    And I am also going through a shock cycle. It is recomending me get the FC to around 20. I am very gun shy to pout that much bleach in my pool. I am up to about 6 gallons so far today. Is this normal? My FC is falling pretty quickly as I am checking it every 30 to an hour.
    Brent
    29,000 Gallon In Ground Pool, Blue Gem Quartz Finish, DE Filter, Completed 9/7/12
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New to BBB I have a question.
    50 if you do not have a Saltwater Chlorine generator (swg). 53 is close enough to 50...in fact it is essentially the same number since the test accuracy is +/- 15 ppm (in the 30 to 90 ppm range).
    Should I be gun shy about dumping gallon after gallon of bleach into the pool per the pool calculator?
    Brent
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Quote Originally Posted by rabbitdundied
    No.
    chiefwej
    Thanks 7 jugs down off to buy out Kroger.
    Brent
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Can you post your pool and equipment specs in your sig? It helps us help you.
    by the way I forgot...
    Welcome to tfp, rabbitdundied
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You must have a big pool?
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Welcome fellow Arkansas-an! You will love, love, love this site!
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    20,000 gal vinyl rectangle
    Heyward Filter Pro Series
    1 hp pump
    anything else?
    Brent
    The shock calculator recommended I get the FC up to 20. My test kit only reads to 6 so I am off to purchase another. I think by estimation it is up around 8-10 right now while shocking.
    Brent
    38,260
    You really should just order one of the recommended test kits (see link in signature). The FAS-DPD chlorine test is the only test that will reliably test at the high FC #s needed while shocking ... and it is very rare to find that test locally (it is like the pool stores do not want you to know about it ... and further weird, most pool stores do not use it for their own testing).
    Chlorine FAS-DPD Service Test Kit
    Item# Product Qty Price
    81329
    $74.99
    (2 reviews)
    Read 2 Reviews
    Write a Review
    Prices and availability may vary between stores and online.[attachment=0:20zz7jzm]pool test kit.jpg[/attachment:20zz7jzm]This is the one the local store carries. Will this work?
    Brent
    38,260
    That is the same as the K-2006. That is correct (although kind of over-priced for what you can get it for at tftestkits.net)
    Make sure they do not try to pull a bait-and-switch on you and say the DPD Test Kit (K-2005) is the same thing.
    If you end up purchasing the Taylor kit get the 2006c kit
    It has the larger 2oz reagent bottles.
    18' x 33' Aqua leader AGP (~19k gal) w/hayward swimpro voyager cartridge filter and 2hp hayward pump.
    8 Gal LQ, hayward heater.
    You should have seen the looks I got buying 12 bottles of bleach at WM. One lady gawked so much I told her I was getting rid of a body.
    Brent
    May 2011
    Clearwater, FL.
    446
    It's after midnight and I'm laughing my off!
    Hi rabbitdundied and a great welcome to TFP!
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Done with the shocking process, still slightly cloudy.
    20000 gallon
    vinyl rectangle
    1hp with Heyward filter
    I still have not received my elaborate testing kit so I am working with what I have.
    FC 6
    pH 7.6
    TA 70
    CYA 50 cannot measure but this is what it was 2 days ago based on what my pool store advised me.
    CH cannot test yet
    Borate cannot test yet
    The pool has been clearing up slowly. After starting with a green bottom pool. I now show no signs of visible algae. The overnight test showed a drop from a FC of 5 to a 4 so I think I have finally finished the shocking process after two days of shocking. That is if I am doing things correctly.
    I have vacuumed the pool and I can now barely see the bottom of the deep end.
    Two Questions:
    The pool has a soft feel to it. And after swimming our skin is really dry. Is something else not correct I am not considering?
    Should the pool take this long to clear up?
    BTW thanks for the help this site is awesome.
    Brent
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Done with the shocking process, still slightly cloudy.
    I hate to be the bearer of bad news, but you're not done shocking.
    There are 3 tests that must be passed. The first two you can't really be sure of, because your FC test probably isn't accurate enough. The third test: "the water is clear", hasn't passed yet by your own admission "I can now barely see the bottom of the deep end."
    Two Questions:
    Once you get the fancy test kit and get all the readings, you'll have a clue if something is out of whack and why your skin gets dry.
    Two days would be almost a record for clearing a pool. And as I said above, you're not done yet. Keep up the bleach.
    I don't mind bad news. That is why I asked. Thanks. Back to shocking. Thanks
    Brent
  20. Back To Top    #20
    Ok I went back and re-read the how to shock your pool process. That was my fault in the first place.
    My crappy test kit says my TC which is what I assume they are claiming as FC is well above 5 which is the highest it reads. It also says my CC is well above 5.
    My question is this. Will the CC fix itself with continued shocking or do I manipulate this somehow that I have missed?
    I hope I can make it through this shocking process with this cheapo kit I have or my new kit makes it by the time I really need it.
    Brent
