Thread: Great idea... You tell me
    Jun 2012
    Escondido, CA.
    42
    How many of us have fogotten that we've opend the fill valve on our pools... I've done it twice now... I've avoided an accident but I'm figuring that its a soon or latter thing....
    So I started looking into automatic pool fill valves/sensors etc... $$$ ouch
    But then I had this idea.. how about putting a hose bib timer inline with my fill pipe or an inline irrigation valve... and use either a manual mechanical timer to turn off after a given time 30,40,50 min etc or find a digital one that I can set and pretty much ignore. No wires to run.. no funky float valves... no dodads hanging off the side of the pool
    Assumming I keep track of my evaporation rate and can figure out my fill rate thru my pipe I might.. just might avoid overflowing my pool...
    Escondido Ca [*]~23000 gallon plaster pool built in the 70's[*]Pentair VF Pump running 10hrs at 1800rpm getting and estimated 35-40 GPM thruput[*]Sta-Rite Cartridge filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Great idea... You tell me
    Jun 2012
    Escondido, CA.
    42
    Quote Originally Posted by JohnT
    Ha!.. I didnt say I was smart or orginal... I just had the idea... Im just not brain dead.. thanks for the link
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Yep, it works quite well. I have an auto fill on my pool, but I have a fountain out front of the house, and with the evaporation rate here in the desert...... I just ran a fill line from my existing irrigation system and gave it it's own zone. It stays full and I seldom even need to change the settings.
    Since I already had a system the cost was just some tubing and a valve, about $25 for the whole project.
    chiefwej
