Results 1 to 7 of 7
Thread: Liner has a white coating
    frogman_94's Avatar
    Jul 2011
    Cameron Park, CA
    16
    To start, I got this splash pool last year for a steal. The liner never looked blue but I thought it was due to its age. I noticed yesterday when I vacuum it was leaving brush marks on the bottom. So I got to thinking, can I scrub the white stuff off and have a blue pool again. I got out a green scrubby and with my foot started scrubbing the bottom. The white started to come off.
    My question is what causes the liner to get the white coating and is there an easy way to remove it? I spend about an hour with the green scrubby under my feet and I only got about 1/6 of the pool done.
    13x25 SplashPool (10,600 gal) AG
    20" Sand Filter with 1HP pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Liner has a white coating
    If it is only on the bottom I would guess it's either calcium scale buildup or salt buildup due to allowing the pool to evaporate down to zero. If it is on the wall then I would guess it is calcium scale.
    If you properly maintain your pool chemistry, you will not have the problem in the future.
    frogman_94's Avatar
    Jul 2011
    Cameron Park, CA
    16
    Is there any easy way to remove it?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Sounds like your having success...are you doing this with the pool empty?
    frogman_94's Avatar
    Jul 2011
    Cameron Park, CA
    16
    No, the pool is full.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Post a full set of test numbers. If it is calcium you may be able to get it into solution by keeping you Calcite Saturation Index (csi) lower. If it is salt, time may cause it to disolve. If it is some soap/surfactant time and brushing along with proper chlorine levels may be the only way.
    frogman_94's Avatar
    Jul 2011
    Cameron Park, CA
    16
    I'll post my numbers tonight when I test.
