Thread: SWG and spa
    Jun 2012
    NJ
    50
    SWG and spa
    When I have the spa isolated so that the only water being filtered is the spa (vs the pool also), should the SWG be turned off? Is it safe to be in the spa with the SWG running?
    24,000 gallon in-ground plaster, Pentair FNSP60 60 sq. ft. DE filter @ 9,000 GPH, 2HP WhisperFlo pump, CircuPool RJ45 SWG, 399k BTU Raypak heater, built 2008. Taylor K2006C kit.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: SWG and spa
    I should be safe for a short period of time, but the SWG may over-chlorinate that small volume quit quickly. The best way to know is to do a non-soaking test run and test FC at the beginning and then test every few minutes till you would have gotten out to see how high the FC levels are. If below the shock level for you cya concentration, then it should be fine in terms of safety.
    Jun 2012
    NJ
    50
    Re: SWG and spa
    Great idea! Thanks!
