Results 1 to 8 of 8
Thread: Wasp/yellow jackets
    Wasp/yellow jackets
    on 5 acres of land with a large pool.....wasps/yellow jackets are taking over the pool!! they come in waves ALL DAY LONG. 10-20 at a time....have tried everything and yes, tried to find the nest(s). any solutions??
    Atlanta, GA
    18' x 36' :: IGP :: ~27,000 gallons
    Hayward Super Pump 1hp
    Hayward Sand Filter s244s
    Pool Pilot SWG DIG200
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Re: Wasp/yellow jackets
    Some have claimed that having 30ppm Borates in your water will keep them away. I have not tried this, but also rarely get them near my pool.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Aug 2010
    Dallas, TX
    4,052
    50ppm of borates worked for me. At first they still came, but over time they quit coming.
    Apr 2009
    South Texas
    177
    It's ok to put borates in a bbb pool? If so, what do I put in the pool to add borates and how do I figure out how much? How will it effect other readings and how do I test for borates to stay on top of it? On 10 acres and can't possibly keep up with all the nests.
    Just bought a new house in the country, no pool yet. :(
    Hot tub..500 gals..bromine
    TF100 test kit and speedstir
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    We've had pretty good luck this summer with a number of "steps".
    1) Marigolds. Wasps aren't fond of the smell. A couple of marigold pots near the steps or ladder help a bit.
    2) These wasp traps have worked exceptionally well for us, using apple cider as the bait. We've found them at Aldi for half the price shown on that page.
    3) Drowning them. Wasps can't swim, and are surprisingly prone to drowning. Just splashing them with water from the pool a couple of quick times tends to knock them deep enough into the water they can't fly out. "Escort" them over to the nearest skimmer, viola. You'll also find that they don't seem to take being splashed by water as an aggressive act. I've not yet had one turn on us or the kids (and believe me...I'm attentive to it, as I and the wife are both allergic), but instead they simply fly away if they escape the splash.
    4) Bleach water. We keep a pressurized spray pump (Bought at Big Lots for $2) filled with a 50% mixture of bleach and water. It knocks them off of stairs, handrails, etc, and down into the water (see #3 above) without introducing anything scary to the pool. If you have a wood deck, might want to check for discoloration if you're concerned about such things.
    It takes a while, and you need to be pretty diligent about going after them when they're there, and changing the traps and such, but all these steps work surprisingly well. it even appears, at our pool at least, to have "sunk in", and reduced the number we're seeing overall.
    As for the borates, you can view this thread to answer your questions.
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    Aug 2010
    Dallas, TX
    4,052
    Borates is one of the items BBB uses. It comes from the Borax part of BBB.
    Read this thread, it should have all your info.
    so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html
    EDIT: Gordon beat me!
    We have a few marigolds around our pool too.
    I know this is an old thread. but I had the same issue as the OP. Paper wasps would literally run us out our pool. We would look out the window and see the wasps enjoying our pool more than us.
    Then I found a product called Viper. Purchased it on amazon. Our Wasp problem reduced by about 97%. We still get the occasional one or 2 fly by. But nothing like before. We used to go through 4-5 cans of wasp spray a week, which can get pretty costly.
    Ive been using this products for 2 summers now. It works miracles. It does not kill wasps on contact. But it does keep them away. My initial experience was that I applied it, and thought it didnt work. But about a week later, we saw very little wasps. So every 2 or 3 months I do an applications, and my backyard continues to stay wasp free. Hope this helps anyone looking to take their pool back!
    Good Luck!
    The stuff is strong and it works. Read the reviews on it. This stuff saved my pool experience.
    Amazon.com : Viper Insect Concentrate 16 oz : Home Pest Repellents : Patio, Lawn Garden
    20,000 GAL, 16 X 32 IG Vinly Pool, Sand Filter, & 1.5 HP Hayward - Hot Spot Relay Hotub
    N. Mississippi.
    Jun 2015
    Dallas, TX
    148
    Quote Originally Posted by Trey9007 View Post
    Good Luck!
    Where around your pool did you actually apply this stuff?
    9,000 gallon IG pool with spa, Pentair FNS Plus 48 DE filter, 2HP Whisperflo pump, 0.75HP Letro booster pump, Polaris 280 cleaner, EasyTouch controller (originally a Compool LX100 that was upgraded via Pentair's upgrade kit), TF-100 kit
