Thread: Removing LED Lights
    Jun 2012
    Ontario Canada
    12
    Removing LED Lights
    Currently shocking the pool and failed the OCLT test by .5 twice. Scrubbing around the LED light niche a large amount of black came off. Is this a sign the algae is behind the light niche? If yes do I need to drain the water level below the light fixture in order to remove the light?
    Thanks
    Andrew
    30K Gallon 18x36, Sand Filter, IG Vinyl, 1HP Hayward, Aquarite SWG, Jandy Lite2 Gas Heater
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Removing LED Lights
    Algae in the niche isn't going to grow. It needs sunlight.
    Jun 2012
    Ontario Canada
    12
    Thanks, I will keep the light intact and keep shocking
