Thread: SWG Does not seem to be generating chlorine
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    I have my swg set at 50% and it runs for 8 hrs/day.
    I cannot seem to keep fc in the pool.
    CYA---60 (a little low but should be OK)
    pH----7.5
    CC---0
    Last week I was on vacation and when I got back my fc was 1 and cc was.5
    I tried to get my fc back up but have not had much luck.
    Yesterday I dumped in 2 gals of 9% to got the fc level back up and eliminate the cc.
    This worked, but this morning it is back to 3fc from 7 and no cc.
    My cell has no scaling on it andit seemed to be working perfectly a few weeks ago.
    I suppose I could just increase the % but from other posts and the fact that it is oversized, I should not have to.
    Suggestions?
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: SWG Does not seem to be generating chlorine
    [center:18h3dxca]Sounds like you're just barely keeping an algae bloom in check.
    [youtube:18h3dxca]uijLXS-IJZM[/youtube:18h3dxca][/center:18h3dxca]
    Do an overnight FC loss test to see if there are organics in the water consuming chlorine. If there are you need to shock the pool.
