Results 1 to 7 of 7
Thread: Is The Taylor K-1766 Salt Water Test Kit Decent?
    Jul 2007
    Hillsborough, NC
    525
    I need one now that I am no longer using a seasonal pool. If so, I will order it.
    I have the K-2006 already and I am happy with it.
    thanks
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Re: Is The Taylor K-1766 Salt Water Test Kit Decent?
    Yes, the K-1766 is the best available salt test. It is a little bit tricky to use, but not a big deal.
    The AquaChek salt test strips are the second choice. They are simpler to use and usually quite good, but they aren't as reliable.
    22,553
    I use it and it works very well. Pay close attention to the instructions (which you should do with any test) and you won't have a problem at all. I have never accidentally missed the endpoint. I've purposely gone by the end point to see what it would look like, and it's really distinct that you've done it.
    Jul 2007
    Hillsborough, NC
    525
    Thanks. I just ordered it.
    Montreal Canada
    326
    It's easy to over-titrate, or go past the proper endpoint (it's salmon/orange colored), not brown (mix one drop of each reagent to see). I'm now using a 25 mL water sample (instead of the 10 mL per the instructions), each drop is 80 ppm, way easier to perform the test without overtitrating.
    Jun 2012
    NJ
    50
    SpeedStir makes it much, much easier. And for some reason, this test just makes me ill looking at it--kind of a gross looking endpoint.
    24,000 gallon in-ground plaster, Pentair FNSP60 60 sq. ft. DE filter @ 9,000 GPH, 2HP WhisperFlo pump, CircuPool RJ45 SWG, 399k BTU Raypak heater, built 2008. Taylor K2006C kit.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by CaOCl2
    That's what I do as well, though mostly because I'm measuring lower salt levels in the 1000 ppm range and wanted more accuracy so I had another parameter to use to measure water dilution.
